I got up very early this morning and applied the UV blocker to the lower engine cowl outer face. While that was drying I sanded the upper cowling inner face, the oil filler door and the main gear leg upper intersection fairings. I found some more filler was necessary on the gear leg intersection fairings so I mixed some more micro and filled them. With a heat lamp applied the micro was soon cured so I resanded them. Then later in the day with the UV blocker on the lower engine cowl dried I abraded the UV blocker and then painted the cowling.
Lower engine cowling painted
Upper engine cowling sanded after the second micro application
